1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | I removed the front end off my truck today and found the floor rusted through at the lower mount for the inner fender. Can this be patched or should I cut to the chase and replace the entire firewall? Passenger inner fender mount | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I think you need to evaluate and plan for replacing the floor/toeboard and the lower cowl, both inner and outer. Does the DS look the same? This is a very common problem with all of the AD series. There will be good help here to guide your decision and advice along the way. My pictures on similar repairs can be found here. https://www.flickr.com/photos/advance-design_parts_co/8129102309/in/album-72157631867396207/ | | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | Driver side is very similar all 3 inner fender mount bolts broke during disassemble as well. | | |
