| | | Forums66 Topics128,196 Posts1,057,392 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Does anyone have experience in changing ALL the Fluid in a 1954 Chevrolet Hydra-Matic transmission? What is the proper procedure? What is the correct type of Fluid to use? How do you magnetize a drain plug? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I was given Dextron 3 (III ?) by Gene Berck for my 1954 Hydra-Matic.
Original fluid was Dexron or Type-A/Suffix-A
Wikipedia: Dexron-III In 1993, GM released new Dexron-III fluid (GM Spec GM6417M and later GMN10055). It is generally backward-compatible with transmissions using earlier Dexron fluids or Type-A/Suffix-A fluid.
I filled the empty H-M with about 5 quarts (to the fill level on the dip stick) Then, start the engine (rear-end up on jacks). You will hear slurping sounds, and may then slowly add up to required fill (9 qts ?). 8.5 qts on refill 9 qts on rebuild
If no one offers a better answer, glue a magnet to the fill plug? | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Hello Tim,
With rear-end up on jacks, what gear was the H-M in ?
That must be one Pretty transmission from Gene!
Thanks for the info,
Jim | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I think it was in neutral, Jim Send me a PM if you want to hear my experience with Gene. He kindly sent me photos every day. I made a crude website with the photos and with misc info/BS about 40s/50s Hydra-Matics. Hydra-Matic rebuildAt least, check out the HydraMatic Woman song/link on the last page. | | |
