1 members (klhansen), 130 guests, and 2 robots.
Topics128,195
Posts1,057,371
Members48,469
Does anyone have experience in changing ALL
the Fluid in a 1954 Chevrolet Hydra-Matic transmission?
What is the proper procedure?
What is the correct type of Fluid to use?
How do you magnetize a drain plug?
I was given Dextron 3 (III ?) by Gene Berck for my 1954 Hydra-Matic.
Original fluid was Dexron or Type-A/Suffix-A
Wikipedia: Dexron-III
In 1993, GM released new Dexron-III fluid (GM Spec GM6417M and later GMN10055). It is generally backward-compatible with transmissions using earlier Dexron fluids or Type-A/Suffix-A fluid.
I filled the empty H-M with about 5 quarts (to the fill level on the dip stick)
Then, start the engine (rear-end up on jacks).
You will hear slurping sounds, and may then slowly add up to required fill (9 qts ?).
8.5 qts on refill
9 qts on rebuild
If no one offers a better answer, glue a magnet to the fill plug?
Hello Tim,
With rear-end up on jacks, what gear was the H-M in ?
That must be one Pretty transmission from Gene!
Thanks for the info,
Jim
I think it was in neutral, Jim
Send me a PM if you want to hear my experience with Gene.
He kindly sent me photos every day. I made a crude website with the photos and with misc info/BS about 40s/50s Hydra-Matics.
Hydra-Matic rebuild
At least, check out the HydraMatic Woman song/link on the last page.
