4 members (Otto Skorzeny, FAST55, Hawkman, 52GMC35424JD), 91 guests, and 1 robot.
Topics128,051
Posts1,055,768
#1123264 09/09/2015 2:25 AM
On a 54 Chevy 1/2 ton, does the rear edge of the passenger inner fender bolt directly to the toe board panel or is there some sort of spacer required? It looks like there should be 3 bolts.
No spacer, bolts through the floor into the inner fender.
Brad means toe board. (They talk funny in Utah. smile )
Carl
Fox Offline
Is there a gasket or anti squeak material in between?
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Are they on the pass side? I would have to look at my truck which is not available right now, but I thought one side had bolts to toe-board and the other didn't. And yes on anti-squeak between the fender and inner fender.
Captive nuts on the driver's side, and no captive nuts on the passenger side.
There is an attachment "bracket" on the driver's side, and no bracket on passenger side (sheet-metal to sheet-metal).
link to picture of the driver's side bracket (Fender Skirt/Parking Brake Brace)
There should be captive nuts on the inner fender on the passenger side. The bolts which go through the toe board are low profile slot heads (so that they don't show through the floor mat).
Carl
Thanks for the correction, Carl
I removed the front end off my truck today and found the floor rusted through at the lower mount for the inner fender. Can this be patched or should I cut to the chase and replace the entire firewall? Inner Fender mount
U
U Offline
How do I view your picture without signing up for tumblr?
What truck & year model do you have? If you post a new topic in the paint & body forum (this one) there are plenty of folks that will lend some outstanding advice. Here, in this thread, your question & picture might not get seen.
Either way, whatever your picture shows, you can patch it. It might be an entire firewall-size patch, or maybe not- taking the whole thing down to bare metal is the best way to find out.
Brad
Wrench Fetcher, PhD
since everyone else answered the other question.....mine had some sort of antisqueek material when i took it apart.
Chris
Kits are availiable
...link...
