1 members (RLB), 215 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#1122674 09/05/2015 3:56 AM
Hi guys!
I just had a Carter YF2100s with Manuel choke rebuilt by national carbs. I need a pic of how the choke and throttle cable is suppose to be hooked up. Also what do you recommend to cut the cable with to get more cable instead of sheathing?
U
U Offline
If there's not a picture on the Internet already, I'll post one in the morning when I connect my choke & throttle cables to the same carburetor.
The cables are routed to where they pull/push...
On tractors it's called rear pull choke, sometimes, but have you tried the search function on here? Tons of engine photos in the gallery, as well.
Cutting a wound choke cable- metal wrapped? Carefully with a small pipe cutter used for fuel lines. A lot depends on the cable material...
Mañana!
Brad
Wrench Fetcher, PhD
Pull the inside cable out cut outside to fit with a wire cutter, I use a side cutter, push inside cable back into outer cut to fit.
Pete
U
U Offline
Wrench Fetcher, PhD
Thanks! It turns out that rebuilder had my bracket flipped around on the carb where the throttle side was straight up and not pointed down.
Well, wouldn't you know it. I just had this carb rebuilt and I bolted it up today and hooked up the Manuel choke and she won't run. I pull the choke cable all the way and she runs for about 3 seconds and shuts off. Anybody know what would cause that?
U
U Offline
Lack of fuel or air.
Brad
Wrench Fetcher, PhD
Sounds like your rebuilder has something messed up, along the lines of the choke bracket.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
Yep!! I put the Rochester back on and she idles fine. Unbelievable! Sent it off to have it rebuilt and it will not idle!
