7 members (GMCJammer51, walter74, JW51, 3B, J Lucas, Joe H, 1 invisible),
85
Mod | | | Forums66 Topics128,080 Posts1,055,952 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 19 New Guy | | New Guy Joined: Jan 2010 Posts: 19 | Hi guys!
I just had a Carter YF2100s with Manuel choke rebuilt by national carbs. I need a pic of how the choke and throttle cable is suppose to be hooked up. Also what do you recommend to cut the cable with to get more cable instead of sheathing?
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | If there's not a picture on the Internet already, I'll post one in the morning when I connect my choke & throttle cables to the same carburetor.
The cables are routed to where they pull/push... On tractors it's called rear pull choke, sometimes, but have you tried the search function on here? Tons of engine photos in the gallery, as well.
Cutting a wound choke cable- metal wrapped? Carefully with a small pipe cutter used for fuel lines. A lot depends on the cable material...
Mañana! Brad
Wrench Fetcher, PhD | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Pull the inside cable out cut outside to fit with a wire cutter, I use a side cutter, push inside cable back into outer cut to fit.
Pete
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Wrench Fetcher, PhD | | | | | Joined: Jan 2010 Posts: 19 New Guy | | New Guy Joined: Jan 2010 Posts: 19 | Thanks! It turns out that rebuilder had my bracket flipped around on the carb where the throttle side was straight up and not pointed down.
| | | | | Joined: Jan 2010 Posts: 19 New Guy | | New Guy Joined: Jan 2010 Posts: 19 | Well, wouldn't you know it. I just had this carb rebuilt and I bolted it up today and hooked up the Manuel choke and she won't run. I pull the choke cable all the way and she runs for about 3 seconds and shuts off. Anybody know what would cause that? | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Wrench Fetcher, PhD | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Sounds like your rebuilder has something messed up, along the lines of the choke bracket.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Jan 2010 Posts: 19 New Guy | | New Guy Joined: Jan 2010 Posts: 19 | Yep!! I put the Rochester back on and she idles fine. Unbelievable! Sent it off to have it rebuilt and it will not idle! | | |
