4 members (Jay R, Chris's 46 / 515, Peggy M, Hotrod Lincoln), 54 guests, and 1 robot.
Topics128,042
Posts1,055,597
#1122180 09/02/2015 5:47 AM
I have a 1954 4400 1.5 ton with a broken front spring. I also have a set of front springs from a '54 6400. Any issues with installing the 6400 springs on the 4400?
ROUGIE #1122182 09/02/2015 6:48 AM
I believe the leaves are the same thickness on the 4000 and 6000 series trucks, so you might be able to use the 6000 springs for replacement parts on the 4400.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
ROUGIE #1122193 09/02/2015 1:08 PM
http://chevy.oldcarmanualproject.com/chevyresto/54135.htm
The standard 1954 4400 and 6000 series springs look to be the same.
Probably no need to post this: if pivot/shackle pins/bushings look worn and/or are loose, you might want to replace them.
