3 members (Hotrod Lincoln, BC59, 1 invisible),
134
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,047 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 43 'Bolter | | 'Bolter Joined: Oct 2005 Posts: 43 | I have a 1954 4400 1.5 ton with a broken front spring. I also have a set of front springs from a '54 6400. Any issues with installing the 6400 springs on the 4400? | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I believe the leaves are the same thickness on the 4000 and 6000 series trucks, so you might be able to use the 6000 springs for replacement parts on the 4400. Mike B  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | http://chevy.oldcarmanualproject.com/chevyresto/54135.htmThe standard 1954 4400 and 6000 series springs look to be the same. Probably no need to post this: if pivot/shackle pins/bushings look worn and/or are loose, you might want to replace them. | | |
