4 members (WICruiser, Gdads51, TUTS 59, Otto Skorzeny), 71 guests, and 1 robot.
Topics128,049
Posts1,055,684
#1121996 09/01/2015 5:19 AM
If I was wanting to replace all nuts and bolts on front end of my 57 1/2 ton where would I find such kits? Inner fender bolts, fender bolts, etc.
U
U Offline
I'm sure somewhere sells the kits - why not make your own "kit" up? Take each bolt off & measure it with a caliper, noting their thread pattern, & also the dimensions of any washers. I put these in a Ziploc bag, labeled the outside of the bag, & then counted the total number I needed by going over the truck. I multiplied that number by two for extras.
Inner fenders are attached to fenders with 5/16"-18 cap screws; same for the radiator support to fender mounting points. 1/2", 3/4", & 7/8" lengths will probably do the trick all the way around. I am unsure what size I used to attach the fender braces.
Replacing bolts is a dangerous undertaking; it can lead to replacing a lot more parts. Lock all of your sanding, grinding & wire wheel tools up. Focus only on the bolts in a one-for-one exchange & you'll be done in no-time. You will probably need to have a tap & t-handle handy, a torch... BFH...penetrant...wasp spray... But, I have no idea what the condition of your truck is.
Brad
Wrench Fetcher, PhD
stainless kits available at Jim Carter or American Classic among others
Ex Hall Monitor
Ex Hall Monitor
Welcome back Bill!! I was afraid you'd written us off. grin
