Brrrr
place holder
0 members (), 136 guests, and 2 robots.
Topics128,274
Posts1,058,431
Members48,489
#1121832 08/31/2015 9:46 AM
Moderated
Moderated
REGARDING SIDEMOUNTED SPARE TIRE BRACKET, I AM SEEKING MOUNTING INFORMATION. I HAVE THE ASSEMBLE MANUAL BUT WOULD LIKE TO CONFIRM THE DEMENSION FROM THE STAKE POCKET TO THE FIRST ANGLE SUPPORT. DOES ANYONE HAVE ONE OR A PHOTO; HATE TO DRILL INCORRECTLY. THERE IS CONFLICTING INFORMATION IN THE MANUAL.
Mine is a 3/4-ton (3604) and 4.63" is called out in the FAM, but
for what it's worth, I get right around 4" from the back side
of the front pocket to the front side of the first vertical
angle. My spare fits fine.
The call out for the 1/2-ton (3104) would be 2.88".
DG
Denny G
Sandwich, IL
** I'm in the same position cronis. I think I'm going to mount the tire mounted on the wheel I'm going to use & set it in the fender indention with a 1/8 inch spacer between the tire & fender and hold the tire & wheel assy. in the indention then drill where the tire bracket mount bolts are located on the bed side wall??? Any of you guy's see anything wrong with my thoughts??
On my 1/2 ton 54 I have 2 3/16" from the back of the stake pocket to the inside flat of the first support. My 6.50 x 16 fits fine. Tom
