| | | Forums66 Topics128,140 Posts1,056,771 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2015 Posts: 1 Moderated | | Moderated Joined: Aug 2015 Posts: 1 | REGARDING SIDEMOUNTED SPARE TIRE BRACKET, I AM SEEKING MOUNTING INFORMATION. I HAVE THE ASSEMBLE MANUAL BUT WOULD LIKE TO CONFIRM THE DEMENSION FROM THE STAKE POCKET TO THE FIRST ANGLE SUPPORT. DOES ANYONE HAVE ONE OR A PHOTO; HATE TO DRILL INCORRECTLY. THERE IS CONFLICTING INFORMATION IN THE MANUAL. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Mine is a 3/4-ton (3604) and 4.63" is called out in the FAM, but for what it's worth, I get right around 4" from the back side of the front pocket to the front side of the first vertical angle. My spare fits fine.
The call out for the 1/2-ton (3104) would be 2.88".
DG
Denny G Sandwich, IL
| | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** I'm in the same position cronis. I think I'm going to mount the tire mounted on the wheel I'm going to use & set it in the fender indention with a 1/8 inch spacer between the tire & fender and hold the tire & wheel assy. in the indention then drill where the tire bracket mount bolts are located on the bed side wall??? Any of you guy's see anything wrong with my thoughts?? | | | | | Joined: May 2009 Posts: 11 New Guy | | New Guy Joined: May 2009 Posts: 11 | On my 1/2 ton 54 I have 2 3/16" from the back of the stake pocket to the inside flat of the first support. My 6.50 x 16 fits fine. Tom | | |
