1 members (klhansen),
136
10
Mod | | | Forums66 Topics128,281 Posts1,058,470 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I am installing a fourlink rearend on a 53 chevy pickup half ton frame. There are two holes at the top of the rear of the frame. I need to know which one is the rear bed bolt hole. My measurement to put the new fourlink crossmember in comes off the rear bed bolt hole. My 53 now sits on a wagoneer frame, so I can't use it to check which hole is the correct one. Thanks! | | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Coach, Assuming the 1953 Chevy 1/2 ton is similar to my 52 Chevy 1/2 ton: There are two holes on top of the frame at the rear. The end hole is for the bed on each side. Hope this helps.
52pu
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
| | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | Oh, no. Is the frame really supposed to have holes ? ! | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Thanks 52pu. It appears my kit from TCI for the rear doesn't follow their written instructions for installing it. I had to make some adjustments. The 4 rails of the 4link are too short. Had to send them back to get longer ones made. | | |
