1 members (Hotrod Lincoln),
130
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | 55.2 Chevy 3100 235 12v Gauge Cluster Questions What do I need to do to use an electrical temp gauge (in the cluster) when I previously had the 55.2 mechanical temp gauge? A while back I got a remanufactured Gauge cluster at a good price; everything was tested, certified, et cetera, but I am just getting around to figuring out what I need to go from the engine to the electric temp gauge in the new cluster. Simple? Easy? Rear window weatherstrip difficult? I have not figured out our new search yet. I also couldn't find any part(s) to make this happen---but, that's why I'm asking- I really am unsure what to look for. Thanks for any advice on this. Brad Wrench Fetcher, PhD | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | 55.2 did not have an electric gauge so your cluster probably has a 56 or up, which uses an O'Reillys WT203 (TS6) sender. Screw it in the motor where the other one was and wire it to gauge. Easy. One gauge post says "S" sender, other says "I" or + , hot wire.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | What type of terminal end goes on the button connection on the temperature sender? I had one of those (maybe more) leftover from the cracked cylinder head replacement days. Fits like it belongs there (because it did). Learning as I go- thanks for the info. Brad Wrench Fetcher, PhD | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Sender (Switch)OR a standard crimp-on, 1/4, female, blade terminal. Terminal
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | On original wiring: Pink wire from Ign post to accy on ignition switch. Green wire from sender post to sender | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | I got the 1/4" female terminal connection, and only had time to check its fit. On original wiring: Pink wire from Ign post to accy on ignition switch. Green wire from sender post to sender Can you elaborate on this? Thanks! Brad Wrench Fetcher, PhD | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Gail is telling you the normal Chevy wire colors to wire gauge/sender per post 1120612 above. Regarding the hot lead or + lead to gauge: I would wire from "ON" terminal on ignition switch to gauge fuse, than back to gauge. The ignition switch batt terminal is usually direct wired to battery, But even that should have a Fusible Link. Everything wired to the ignition "on" terminal should go thru fuses then to component or it's switch.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | As a follow up, and honesty check- the Classic Parts wiring harness I had purchased to install ended up being wired/prepped for the electrical temp sender.
I learned a lot, either way, so this thread wasn't a waste of time.
Brad Wrench Fetcher, PhD | | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | Hi Brad,
Are you all set? Your last post is a little confusing. I am running the same harness and a v6 (not 6v) ignition switch. V8s didn't have floor starters so they had three positions and different posts on them. Their original replacement harness uses the same colors as originals. I got the one with the numbers printed on it.
Pink wire from one of the four "accessory" prongs on my ign switch to ign post on the gauge. (has Ign or sender written on the cardboard behind the nuts on the gauge posts). Then you get your green wire from the sender on the engine to the sender post.
If you were looking at the back of the housing not the gauge faces... Sender post would be on the left and ign post would be on the right.
Hope that helps you get it all set up. | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | All is good; my wiring harness came 'wired' for a cylinder head with an electric sender, so I had in hand the answer to the original question. That's all I meant by the previous post.
Brad Wrench Fetcher, PhD | | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | Ok great glad you're on the right path. It doesn't take much to kill one with incorrect wiring. | | |
