1 members (Rusty Rod), 80 guests, and 2 robots.
Topics128,127
Posts1,056,680
Members48,452
U
U Offline
55.2 Chevy 3100 235 12v Gauge Cluster Questions
What do I need to do to use an electrical temp gauge (in the cluster) when I previously had the 55.2 mechanical temp gauge?
A while back I got a remanufactured Gauge cluster at a good price; everything was tested, certified, et cetera, but I am just getting around to figuring out what I need to go from the engine to the electric temp gauge in the new cluster. Simple? Easy? Rear window weatherstrip difficult?
I have not figured out our new search yet. I also couldn't find any part(s) to make this happen---but, that's why I'm asking- I really am unsure what to look for. Thanks for any advice on this.
Brad
Wrench Fetcher, PhD
Sir Searchalot
Sir Searchalot
55.2 did not have an electric gauge so your cluster probably has a 56 or up, which uses an O'Reillys WT203 (TS6) sender. Screw it in the motor where the other one was and wire it to gauge. Easy. One gauge post says "S" sender, other says "I" or + , hot wire.
U
U Offline
What type of terminal end goes on the button connection on the temperature sender?
I had one of those (maybe more) leftover from the cracked cylinder head replacement days. Fits like it belongs there (because it did). Learning as I go- thanks for the info.
Brad
Wrench Fetcher, PhD
Sir Searchalot
Sir Searchalot
Sender (Switch)
OR a standard crimp-on, 1/4, female, blade terminal.
Terminal
On original wiring:
Pink wire from Ign post to accy on ignition switch.
Green wire from sender post to sender
U
U Offline
I got the 1/4" female terminal connection, and only had time to check its fit.
Originally Posted by 59ApacheGail
On original wiring:
Can you elaborate on this?
Thanks!
Brad
Wrench Fetcher, PhD
Sir Searchalot
Sir Searchalot
Gail is telling you the normal Chevy wire colors to wire gauge/sender per post 1120612 above. Regarding the hot lead or + lead to gauge: I would wire from "ON" terminal on ignition switch to gauge fuse, than back to gauge. The ignition switch batt terminal is usually direct wired to battery, But even that should have a Fusible Link. Everything wired to the ignition "on" terminal should go thru fuses then to component or it's switch.
U
U Offline
As a follow up, and honesty check- the Classic Parts wiring harness I had purchased to install ended up being wired/prepped for the electrical temp sender.
I learned a lot, either way, so this thread wasn't a waste of time.
Brad
Wrench Fetcher, PhD
Hi Brad,
Are you all set? Your last post is a little confusing. I am running the same harness and a v6 (not 6v) ignition switch. V8s didn't have floor starters so they had three positions and different posts on them. Their original replacement harness uses the same colors as originals. I got the one with the numbers printed on it.
Pink wire from one of the four "accessory" prongs on my ign switch to ign post on the gauge. (has Ign or sender written on the cardboard behind the nuts on the gauge posts). Then you get your green wire from the sender on the engine to the sender post.
If you were looking at the back of the housing not the gauge faces... Sender post would be on the left and ign post would be on the right.
Hope that helps you get it all set up.
U
U Offline
All is good; my wiring harness came 'wired' for a cylinder head with an electric sender, so I had in hand the answer to the original question. That's all I meant by the previous post.
Brad
Wrench Fetcher, PhD
Ok great glad you're on the right path. It doesn't take much to kill one with incorrect wiring.
