3 members (jay d, 2 invisible),
54
Mod | | | Forums66 Topics128,009 Posts1,055,292 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | This question arose at the A & W Thurs evening. A nicely restored '41 Chev pickup cruised by. Its tail and brake lites were clearly malfunctioning. We mentioned it to the driver who responded that the work had been done by a high-end restoration shop and he can't imagine what the problem could be. Underneath are fresh wood cargo box mounts that suggest that the problem (which the owner seems reluctant to acknowledge) is that the lites are not grounded (are wired to the box which is isolated)
What is the correct setup? Wire individual lamps to the frame or run a strap from box to frame and if so, where does a strap normally get installed? If the latter, is a strap available from suppliers or would you just rig up a battery strap?
sandra
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | A good ground strap to the frame is never a bad idea. But, originally from the factory the box would be grounded at numerous points thru the fender to the running boards and aprons via their bolts to the frame. The current draw is very small for the single or dual tail/brake lights of the day so it didn't require much of a path to complete the circuit.
If the restoration shop was SUPER careful when assembling the truck it is possible, that it was kept insulated by the layers of paint, primers, gaskets, fender welting from establishing a good ground. Tightening the bolts SHOULD have cut into the bare metal enough to establish a ground but it is also possible that it didn't. Bottom line is.....ground straps are a guarantee that there is a complete ground return. dg
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Sandra,
An excellent question.
Many of my restored Suburban's lights behave as you describe (especially the three rear lamps). We stripped and painted all sheet metal. The epoxy primer and urethane finish-coat is probably resulting in very poor grounds.
I have excellent original ground straps (and a few additional ground straps) and they all have excellent/clean connection-points.
I have been neglectful in fixing this dangerous situation. The annual inspection/inspector lets me get by with the very dim and sometimes erratic rear lights/lamps.
I plan to use a small diameter metal-brush drill bit to clean out sheet metal screw holes. After I get bare metal, I'll use a conductive anti-oxidant grease to allow conductivity but prevent rust.
Some holes are not accessible to a drill. I'll probably run an unsightly ground lead to a screw on those lamps/lights.
I'll test the quality of grounds with a continuity tester.
I'll do the wire drill-bit/brush in screw holes before I install sheet metal on the two trucks we are restoring. | | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | It has fender welting around both fenders and continuing to the running board ends
However it also has a rear bumper & the brackets are of course bolted directly to the frame, so perhaps those brackets would make a good ground(?) | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you want to check the quality of existing grounds to lamps. Use a long electrical lead between the battery ground and the lamp (connect the lead to lamp attachment screw, if it is accessible). See if the lamp becomes brighter (I'd do it at night). | | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | Tail lites/mounting brackets are familiar style sold by Jim Carter (and others) for restorations of the 1941/46 era
What is "lamp attachment screw" please? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The attachment screw/post on a lamp/light - the ground would be made from the sheet metal (or frame) to that screw/post. | | |
