| | | Forums66 Topics128,212 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 35 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 35 | Removed the pressure plate and clutch and not realize the clutch face differs on each side.
Which is the front, and which is the back?
Also, is there a front and back of the trans pilot bearing in the flywheel? | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Usually the disc will not go on properly if the wrong way, springs hit flywheel;
If pilot brg. looks the same, either way, if a radius on the inside, that should go out for ease in installing clutch shaft.
| | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | I'm not sure what model you're working on, but there are a number of old Chevrolet service manuals here. A typical clutch for use with a 216 (1947 in this case) is shown here. Guessing that you might be working on a mid-30's (from your handle), these might be of greater interest: 1938 and 1934. Hope one of these links is helpful. Good luck and have fun. Bill
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | | | | Joined: Jun 2014 Posts: 35 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 35 | Great help here thanks. It s a 35, so the34 picture helped. Can the pilot bearing be reinstated without the special tool shown in the old chevy manuals? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Do you have a pilot bushing or a bearing? | | | | | Joined: Jun 2014 Posts: 35 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 35 | It's a bearing with ball bearings in it | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I would think you would want something that applies the force to the outer race as that is where the interference fit will occur. | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Can the pilot bearing be reinstated without the special tool shown in the old chevy manuals? I would use either a small section of pipe that has slightly less OD than the bearing, or a socket as a "driver" tool. | | |
