2 members (Hotrod Lincoln, Hush), 58 guests, and 4 robots.
Topics128,021
Posts1,055,355
Members48,420
#112147 11/10/2001 3:39 PM
hello,although im not doing it right know(actually pretty far off from getting the truck painted)i was wondering how you put flames on the truck,i know most on this site perfer stock,but if you know anything about it please help me,wanna know for a 54.thanks smile
Its not a truck unless you can throw a dead cow in the back
#112148 11/10/2001 4:19 PM
I'm thinking they make templates... I'm sure somebody will be along that can tell ya for sure though.
May the force be with you - SoloWookie
solowookie.com
#112149 11/10/2001 6:32 PM
http://www.customflamepainting.com/how_to/index.html#4
I AM SURE THERE ARE OTHERS WHO HAVE DONE THIS TO THEIR TRUCKS BUT I THOUGHT THIS MIGHT BE A PLACE TO START. ..........G grin
#112150 11/12/2001 3:09 PM
Pat & Larry Kytola wrote the book: How to Paint Flames. It's out of print, but I've seen it around in some catalogs. John Kosmoski's House of Kolor has a video where they flame out a Camero. The really good guys just take narrow masking tape and lay out the flames freehand. Fill in the rest with tape and masking paper. The skill/talent is in the lay out, color transition, and pin striping.
There is no problem so great that it cannot be solved by the application of thought, elbow grease and copious amounts of CASH.
Snappy
#112151 11/13/2001 3:57 PM
thanks for the info guys it was a big help smile
#112152 11/13/2001 7:06 PM
V
V Offline
House of Kolor has a "Bag o' Flames" template kit that is supposed to make it fairly easy to paint flames. Generally speaking, House of Kolor makes the "best of the best" custom paint stuff.
#112153 02/07/2006 7:34 AM
Junior Member
Junior Member
Has anyone ever heard of Paint With Pearl? They sell the same stuff as the big companies, but a totally differnt method. Instead of buying the paints, you buy the pigments and pearls to mix with clear coat. It has really proved to be a benefit to me.
http://www.paintwithpearl.com
#112154 02/07/2006 6:19 PM
Junior Member
Junior Member
the basics of the process
http://www.goldrushsigns.com/GrapeNut.html
Mask, spray the base color, blend in the fades, finish off with a pinstripe. Clear coat if desired.
Plan on a full day and be careful to mask to prevent overspray around tight corners.
a good fade only requires 2 colors and careful transition from light color to darker.
Your design is the most important part of good flames. Crappy design won't make up for nice paint work.
Consider getting assistance from an old hand at this stuff and learn some of the tricks... or hire it out. What you'd spend on the "KIT" stuff you could get a real pro to assist you.
Regarding the Pearl nothing new about adding a dry product to your paint or clear.... just spend your money on good product.... save you some headaches.
GEET
sure it's a nice paint job.....
but something is missing!
