| | | Forums66 Topics128,050 Posts1,055,751 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | I have a 56 three speed. Is there a easy way to install the trans into the engine? Since you can not see the splines to match with the clutch disc,what is the way to do it? Have a lot of patients right. It is on a chain and i can move it all around,just not into the disc/engine. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What size engine?
You will need a clutch alignment tool.
If you bought a new clutch assembly, an alignment tool usually comes with it. | | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | I used the tool to install but it has to be removed to install the trans,correct? Now how do i align the trans spline/shaft into the clutch disc? | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Cut the heads off of two 5 inch bolts which will fit in the two top holes of the clutch housing. Cut slots in the end of them for ease of installation and removal. These are called guide bolts and will make installing the transmission a breeze. As you slide the transmission into place, manually turn the output shaft (transmission in gear) until the input shaft splines line up with the clutch disc hole. Carl
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | It can be helpful to put the trans in 3rd gear. When you get close you can turn the tail shaft to engage the clutch splines. It also helps if the tail of the trans can be tilted a little to line it up as you go in. The guide pins in the above post are most helpful.
Steve H
| | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | Sorry for the delay in answering. The problem is corrected,while pulling the pressure plate down(with the alin, tool) the clutch disc moved enough to not allow the shaft to go in the engine. Loosened the bolts,got it right. | | |
