2 members (60steve, 78buckshot), 75 guests, and 1 robot.
Topics128,212
Posts1,057,468
Members48,471
Removed the pressure plate and clutch and not realize the clutch face differs on each side.
Which is the front, and which is the back?
Also, is there a front and back of the trans pilot bearing in the flywheel?
Crusing in the Passing Lane
Usually the disc will not go on properly if the wrong way, springs hit flywheel;
If pilot brg. looks the same, either way, if a radius on the inside, that should go out for ease in installing clutch shaft.
I'm not sure what model you're working on, but there are a number of old Chevrolet service manuals here.
A typical clutch for use with a 216 (1947 in this case) is shown here. Guessing that you might be working on a mid-30's (from your handle), these might be of greater interest: 1938 and 1934.
Hope one of these links is helpful.
Good luck and have fun.
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill
Great help here thanks. It s a 35, so the34 picture helped. Can the pilot bearing be reinstated without the special tool shown in the old chevy manuals?
Do you have a pilot bushing or a bearing?
1951 1 Ton Completed
It's a bearing with ball bearings in it
I would think you would want something that applies the force to the outer race as that is where the interference fit will occur.
I would use either a small section of pipe that has slightly less OD than the bearing, or a socket as a "driver" tool.
Lots more pictures
