1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | I've had this truck nearly 50 years so I don't remember why I put this piece of chain attached to the throttle return spring when I was a teenager. Obviously because the spring doesn't go the whole distance but what is supposed to be there? http://s23.photobucket.com/user/littlebuddytoo/media/48Chevy/Picture%20067.jpg.htmlThanks Y'all!
1948 AD Pickup
| | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** Looks like the throttle return spring. On the AD trucks the end if the spring you have hooked to the spring would run down to a bolt on the oil pan. | | | | | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | OK, so the end of the spring I have hooked to the chain should instead run to a bolt in the oil pan? I can't picture that in my head since the spring is positioned on a horizontal plane and the oil pan bolts are perpendicular @ 90 degrees from the spring. Thanks for your reply marzak.
1948 AD Pickup
| | | | | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | Great! I'm starting to 'get it' now. My set-up has done fine for nearly 50 years but I knew it's always been wrong. Thanks for the pics tcelderman, I'll tinker with what you and marzak have suggested. Thank you so much!
1948 AD Pickup
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I wouldn't change a thing! I like the farm fix look, and your fix is likely superior to original design. Carl
1948 AD Pickup
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Paul,
That "bracket" might be the clip I gave a link-to in a post above.
What is the year of the engine and the truck that has that clutch return-spring set-up? | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | What is the year of the engine and the truck that has that clutch return-spring set-up? Tim, The engine in the image is a 1958 removed from a 1 1/2 ton truck but the bell housing is from a 1942...that's probably what threw you off. Paul | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks, Paul
I think my trucks' (1954) clutch return springs are set up differently. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Here's the block hook up mentioned earlier That is what I have on my 54z motor ...pic... ...pic... | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | I have the same set up as DADS50, on my 55.2 3100.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That 1954Z photo shows the hole in the block/pan (for the spring). That is what I have on my 1954 engines. Earlier engines are listed using the tab/clip near that location. Later sales photos show different spring connection. illustration shown in 1957 and 1958. | | |
