2 members (RoadsScholar, 1 invisible), 154 guests, and 2 robots.
Topics128,087
Posts1,055,976
Members48,430
#1121098 08/27/2015 2:38 AM
Anyone know of a hydraulic pump attached to the rear of the alternator? Trying to reconfigure the engine area in my COE. what model vehicle would i find one? I did see some with a vacuum pump attached but i need the hydraulic pump for the hydrobooster.
Chris
What year, model/series, and make?
There's a very scarce and expensive generator/PS pump that was used on mid-50's Chevy cars. I've never heard of an alternator/pump combo, but there might be one for some sort of application.
Jerry is right both Mopar and GM had generator/power steering pump combos in the 50's. Check out ebay, there should be some there. Have you thought about driving a pump off the crank snout? A lot of tractors and industrial equipment use direct drive pumps.
SimS
working on a chevy coe 51. putting in a downdraft carb.
hey thanks for the replies. Ill do more research and engineering and see what i come up with
chris
