| | | Forums66 Topics128,066 Posts1,055,871 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | Anyone know of a hydraulic pump attached to the rear of the alternator? Trying to reconfigure the engine area in my COE. what model vehicle would i find one? I did see some with a vacuum pump attached but i need the hydraulic pump for the hydrobooster. Thanks Chris | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What year, model/series, and make? | | | | | Joined: Feb 2004 Posts: 29,776 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,776 | There's a very scarce and expensive generator/PS pump that was used on mid-50's Chevy cars. I've never heard of an alternator/pump combo, but there might be one for some sort of application. Jerry
| | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | Jerry is right both Mopar and GM had generator/power steering pump combos in the 50's. Check out ebay, there should be some there. Have you thought about driving a pump off the crank snout? A lot of tractors and industrial equipment use direct drive pumps.
SimS | | | | | Joined: Sep 2012 Posts: 103 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 103 | working on a chevy coe 51. putting in a downdraft carb.
hey thanks for the replies. Ill do more research and engineering and see what i come up with chris
