0 members (),
68
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 39 Member | | Member Joined: Feb 2001 Posts: 39 | hello all. i was spray-painting a part gloss black rustoleum and those little "fish eyes" appeared! so i let it dry a couple of days, gave it a light sand, cleaned it, then sprayed again. same results. :mad: ive spray-painted alot of my parts and never had this problem before. is the paint bad? what should i do? does the part need to be stripped down completely and redone? thanks!!
1948 GMC 250 Series Flatbed
| | | | | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | The part itself or the paint is contaminated.
Silicone is usually the culprit.
Wiping a mixing stick with a rag that was used for applying Armor All will ruin your paint. Even half a day after Armor All, silicone spray or oil is vaporized, residual will trickle down on your work surface. Air powered tools (impact wrenches, etc) actually vaporize lubricating oil as they are used.
Since you already have paint on the part and holes (voids) have formed, you'll have no choice than to sand smooth.
Are you using a mild cleaning solvent BEFORE spray painting? Not thinner or reducer, they will soften the base.
whizzerick | | |
