| | | Forums66 Topics128,050 Posts1,055,671 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 91 Member | | Member Joined: Oct 2003 Posts: 91 | does anyone know what the pellets that you put in a air dryer are made of ? | | | | | Joined: Nov 2003 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2003 Posts: 86 |
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
| | | | | Joined: Oct 2003 Posts: 91 Member | | Member Joined: Oct 2003 Posts: 91 | is there any thing eles that a guy can use that is cheeper cuz i do lots of sandblasting and it seems like i go through them in about a week | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Find a centrifugal separator. The silica driers are intended for painting. A centrifugal air separator is adequate for sandblasting. It will be more effective if you coil a hose through a 5 gallon bucket of cold water before it gets to the separator, since it helps the moisture condense out of the air.
Also, You can reuse silica pellets by baking them on an old cookie sheet in a low temperature oven (about 180 degrees) until they turn from blue to white again.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Oct 2003 Posts: 91 Member | | Member Joined: Oct 2003 Posts: 91 | i guess i will have to try something diff | | |
