2 members (Brian Moore, J Lucas), 67 guests, and 3 robots.
Topics128,030
Posts1,055,423
Members48,422
#112090 04/04/2004 9:07 AM
does anyone know what the pellets that you put in a air dryer are made of ?
#112091 04/04/2004 3:31 PM
Yes, It's silica gel.
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
#112092 04/04/2004 6:35 PM
is there any thing eles that a guy can use that is cheeper cuz i do lots of sandblasting and it seems like i go through them in about a week
#112093 04/05/2004 7:52 PM
Find a centrifugal separator. The silica driers are intended for painting. A centrifugal air separator is adequate for sandblasting. It will be more effective if you coil a hose through a 5 gallon bucket of cold water before it gets to the separator, since it helps the moisture condense out of the air.
Also,
You can reuse silica pellets by baking them on an old cookie sheet in a low temperature oven (about 180 degrees) until they turn from blue to white again.
Paint & Body Shop moderator
#112094 04/06/2004 10:29 PM
i guess i will have to try something diff
