| | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 165 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 165 | Can someone tell me what this stamped code behind the distributor comes out to?
F527JC
Thanks Kevin
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | How many cylinders? What is it in or what did come out of?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | F527JC F = Flint, MI engine plant 5 = May 23 = 23rd day JC = probably means 235 truck engine with a heavy duty clutch In order to ID the year of the engine you need head/block casing codes and head/block date casting codes: location of codes | | | | | Joined: Dec 2006 Posts: 165 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 165 | Gentleman said it came out of a 1950 chev 3100 And says it is a 235? Would this be a Babbitt engine? Kevin
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Is F527JC located to the left of the distributor on machined flat boss? | | | | | Joined: Dec 2006 Posts: 165 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 165 | Yes that is correct (stamped) on the flat surface. I have not seen this engine, it is information from over the phone.
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | "JC" was used in that format in 1958 and '59...don't know if it was used in '60 as well. If I'm right it was originally in a 4000 series truck. Mike B  | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The JC code would a '58-'62 235, standard engine for '58/ 59 4000 and '60-'62 K10, K20, and C40, also with RPO 227 ( 58-59) and RPO 223 ('60-'62) in 1/2 through 1 ton 2wd models. Both RPO codes are for HD clutch.
Bill Burmeister | | | | | Joined: Dec 2006 Posts: 165 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 165 | Kevin
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | F527JC F = Flint, MI engine plant 5 = May 23 = 23rd day JC = probably means 235 truck engine with a heavy duty clutch The above correct plus add below. 1958-62 235 Thriftmaster JC, Base engine on C40, K10, 20 (C10, 20 30 with RPO 223 Heavy Duty Clutch equipment) Standard Disc 10", Heavy Duty Disc 11" Source; 1960 Chevrolet Truck Resto Pack Actual Pages 5, 7, 23 | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Would this be a Babbitt engine? Nope If you want to pin point the actual year of engine, refer to tclederman's (location of codes) link in previous post. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Provide the information/codes that I suggested you find.
We can then ID the year of the head and block of your non-babbitted rods, insert rod-bearing, high-pressure engine (58-62 235 engine, and maybe later replacement engine). | | |
