4 members (Bill Hanlon, Otto Skorzeny, gswbbc, dt235sd), 83 guests, and 3 robots.
Topics128,047
Posts1,055,532
Members48,424
#1120713 08/25/2015 1:02 AM
Can someone tell me what this stamped code behind the distributor comes out to?
F527JC
How many cylinders?
What is it in or what did come out of?
F527JC
F = Flint, MI engine plant
5 = May
23 = 23rd day
JC = probably means 235 truck engine with a heavy duty clutch
In order to ID the year of the engine you need head/block casing codes and head/block date casting codes:
location of codes
Gentleman said it came out of a 1950 chev 3100
And says it is a 235? Would this be a Babbitt engine?
Is F527JC located to the left of the distributor on machined flat boss?
Yes that is correct (stamped) on the flat surface.
I have not seen this engine, it is information from over the phone.
"JC" was used in that format in 1958 and '59...don't know if it was used in '60 as well. If I'm right it was originally in a 4000 series truck.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
The JC code would a '58-'62 235, standard engine for '58/
59 4000 and '60-'62 K10, K20, and C40, also with RPO 227 (
58-59) and RPO 223 ('60-'62) in 1/2 through 1 ton 2wd models. Both RPO codes are for HD clutch.
Bill Burmeister
Perfect!
Thanks guys
F527JC F = Flint, MI engine plant
5 = May
23 = 23rd day
The above correct plus add below.
1958-62 235 Thriftmaster
JC, Base engine on C40, K10, 20 (C10, 20 30 with RPO 223 Heavy Duty Clutch equipment)
Standard Disc 10", Heavy Duty Disc 11"
Source; 1960 Chevrolet Truck Resto Pack
Actual Pages 5, 7, 23
Nope
If you want to pin point the actual year of engine, refer to tclederman's (location of codes) link in previous post.
Provide the information/codes that I suggested you find.
We can then ID the year of the head and block of your non-babbitted rods, insert rod-bearing, high-pressure engine (58-62 235 engine, and maybe later replacement engine).
