2 members (Peggy M, Simso), 291 guests, and 9 robots.
Topics128,077
Posts1,056,034
Members48,433
#1120687 08/24/2015 11:02 PM
Hi Everyone, quick question.... Do I need to put anything in the cylinders before attempt to start after it up after sitting for three years? About a year ago I put Marvels Mystery Fluid in all the cylinders to keep it Luke.
Scott
Chevytruckdaddy
I don't think it would hurt to add around a teaspoon per cylinder of Marvels now. I would suggest you pull the plugs and turn the engine over with distributer wire disconnected to get some engine oil where it needs to be before 'kicking the tires, and lighting the fire'.
Excellent advice Beltfed, I really appreciate that. 👍
Chevytruckdaddy
I'd be more inclined to pull the dizzy and spin the oil pump a while over adding oil to the cylinder...
Give me ambiguity
or give me something else
Pull the "DIZZY" not sure what you're talking about!
Chevytruckdaddy
you'd be 'dizzy' if you went around and round like the distributor which is what drives the oil pump...
Give me ambiguity
So pull the cap and spin the rotor a bunch of times?
Chevytruckdaddy
Gas Pumper
Gas Pumper
no. Take the distributor out and with a large screwdriver shaft chucked in your electric drill, run the oil pump. This primes the oil pump and allows oil to flow into the engine, rocker assembly, everything. Its a VERY good idea but only if you understand how to pull the distributor correctly.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Sounds awesome but I'm sorry to say I don't know how to pull the distributer correctly. I wish I had that knowledge.....
Chevytruckdaddy
It's not rocket science guys... If I'm correct you can only get it wrong one way and if you can set the timing you can pull the darn thing.
Have you got any bookmarked old chevy manuals or an obsolete paper type laying around? They're usually way more accurate than a forum.... unless HRL it talkin. Then I usually go with his advice.
The forum is a Supplement to the manual not a substitute IMO.
Give me ambiguity
Gas Pumper
Gas Pumper
If you go to the HEI document in the ad on the left, there is a distributor removal instruction. Even a movie showing how to do it. Then break off the handle on your biggest flat tip screwdriver and you are in business. Just heed the warnings about getting it seated properly.
Deve
The Think Tank
