3 members (Ponchogl, dt235sd, mason86), 113 guests, and 2 robots.
Topics128,047
Posts1,055,662
#1120331 08/22/2015 1:59 PM
Just finished installing my crank in my 1956 235 and prior to the pan install I realized the mains did not have any lock washers. I have looked at several engine schematics some of which show lock washers. So prior to last pan install I thought I would seek advice Should a 1956 235 have main cap lock washers?
NO!
Definitely not the split-type spring steel washers. They spread out under load, and can seriously affect torque values. Some main bearing bolts/studs use hardened steel flat washers between the cap and the bolt head or nut, but a properly-torqued bolt of any sort does not need any help from a lockwasher.
Thanks Jerry...I can now tighten the pan bolts with a clear mind set.
I am looking for information on where to purchase a 9 inch clutch and pressure plate to fit my 235. the pressure plate is has 6 bolts and the clutch disc has 10 splines and is 1 1/8 dia.
http://www.classicparts.com/1938-53...-9-1_8/productinfo/90-005K/#.VfODU51Viko
I try to buy the set locally, to be able to quickly check the fit (and easily return it, if it is incorrect).
