15 members (Otto Skorzeny, Jims46, Hawkman, Southerntruck, J Lucas, D B Cooper, Oldcaliforniakid, Stovebolt48, Bill Hanlon, Peggy M, DadsFirstPickup, Ponchogl, Hotrod Lincoln, 32Fordpuchoptop, 1 invisible),
92
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,674 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 46 | Just finished installing my crank in my 1956 235 and prior to the pan install I realized the mains did not have any lock washers. I have looked at several engine schematics some of which show lock washers. So prior to last pan install I thought I would seek advice Should a 1956 235 have main cap lock washers? | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | NO!
Definitely not the split-type spring steel washers. They spread out under load, and can seriously affect torque values. Some main bearing bolts/studs use hardened steel flat washers between the cap and the bolt head or nut, but a properly-torqued bolt of any sort does not need any help from a lockwasher. Jerry
| | | | | Joined: Jul 2013 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 46 | Thanks Jerry...I can now tighten the pan bolts with a clear mind set. | | | | | Joined: Jul 2013 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 46 | I am looking for information on where to purchase a 9 inch clutch and pressure plate to fit my 235. the pressure plate is has 6 bolts and the clutch disc has 10 splines and is 1 1/8 dia. | | |
