7 members (BCBill, Gdads51, Lightholder's Dad, joe apple, Hawkman, greenie-reddy, TUTS 59), 190 guests, and 0 robots.
Topics128,101
Posts1,056,176
Members48,436
#1120142 08/21/2015 3:03 AM
Does anyone know how good the aluminum transmission coolers work? I am referring to the 18 inch x4 3/4 x 2 1/8. long. 2 tube with aluminum fins.
Richard
[email protected]
I am using a aftermarket cooler on T350 trans, its about 12" x 12" x 3/4" thick. It sets under the truck, half under bed, half under cab mounted to the frame rail. I figured air flow was best there. I use no fan or air ducts, the fluid is still as red as the day I put it in back in 2000 and after 10,000 miles.
Joe
Thanks Joe, I have a T350 trans with a 327 engine. I will check out Napa and see what they have. I checked the temp of the trans the other day and it was just above 200 degrees
It depends on the load on the engine and the outside temperature. Heat is a transmission's worst enemy, so if you're towing trailers or moving a heavy vehicle like a motorhome or a 1-ton truck around, definitely use an auxiliary cooler. In very cold weather, the radiator-mounted "cooler" becomes a heater, warming up the fluid to at least coolant temperature and keeping condensation evaporated out. Some people add some T fittings and ball valves to isolate the cooler during below-freezing weather.
Riding in the Passing Lane
Liquid transfers heat many times faster then air. To use the aux. cooler in the return line is fine but by itself it would not be too good.
1972 Chevy c10 Cheyenne Super
I have used a complete air conditioner condenser as a trans cooler on a race car, without using the heat exchanger in the radiator. The cooler was mounted to the roll cage inside the car, rather than in front of the radiator like usual. It worked OK for several seasons with no obvious trans problems.
