2 members (DES57, 1 invisible), 142 guests, and 2 robots.
Topics128,153
Posts1,056,827
Members48,456
#1119562 08/17/2015 10:45 PM
I have a 51 2-ton that has the origianl 20" wheels on 10 lug pattern. I found a set of 22.5" wheels off of a 57 4400. Just trying to confirm it is the same lug pattern as my 51. Is the hub center hole same or larger?
' Offline
According to info from the first post in this thread the bolt pattern is the same as your 51 but the center hole is larger. I have the same 20" wheels on my 49 1 1/2T.
George
The bolt pattern is the same but the hole is 1/2" bigger. They pilot on the hub, so you have to use a 1/4" spacer.
Yep.
4.75",and 5.25" are the diameters in question, larger later.
•1952 Chevrolet 3800 pickup
---All pictures---
This actually works out perfectly since I'm using a newer Dana 80 from a 95 3500hd truck and newer p30 spindles. Both have the larger center hub. And I would have had to bore out the center on my 20" wheels
Happy to report I have the wheels and they fit perfectly!!!
Great, and just as expected.
I have same wheels and axle setup, well my rear is a 70HD but same ends as the 80.
---All pictures---
Same story on '42-'46 1-1/2 & 2 tons. I made 1/4" spacers to fit the newer rims (I went with 19.5 '98 Chevy's.) The have the same bolt pattern, just the larger hub centric hole. Works great.
1946 1.5-Ton Chevy Shorty Bus
All my best --- Tango
