0 members (),
139
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 4 New Guy | | New Guy Joined: Sep 2014 Posts: 4 | HEY FOLKS - HAVING SOME CLUTCH SLIPPAGE IN 4TH GEAR AFTER 6-10 MILES WARM UP. LOWER GEARS SEEM OK.CLUTCH GONE OR MIGHT SOME GEAR OIL GETTING SPLASHED ON IT? 1951 3100 , 4 SPEED . THANK YOU FOR ANY HELP !!! GREAT SIGHT ( NEW AT THIS). BILL --- RUST RIG. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Check your clutch adjustment. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You should have at least a small amount of freeplay in the pedal before it starts to release the clutch. If not the floorboard is partially releaseing the clutch. If that is the problem get under the truck with 2 3/4 open end wrenches & adjust the nuts on the clutch link so you have about 1/2 in. free play at the pedal. If that's not the not the problem you need a new clutch. If it is getting oil on it you will need to take care of that also. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Weak clutches will start to slip in high gear.
| | | | | Joined: Sep 2014 Posts: 4 New Guy | | New Guy Joined: Sep 2014 Posts: 4 | CHECKED FREEPLAY ADJ. LAST NIGHT ( NONE !) WILL ADJ. AND GIVE IT A WORKOUT THIS WEEKEND. THANK YOU FOR YOUR INPUT GUYS !!! BILL
| | | | | Joined: Sep 2014 Posts: 4 New Guy | | New Guy Joined: Sep 2014 Posts: 4 | HEY GUYS, FREEPLAY ADJ. WORKED - NO SLIPPING ( FOR HOW LONG ,TIME WILL TELL). THANK YOU !!! BILL | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | We are glad it worked out for you. Stovebolters prefer you don't use all CAPS in your threads. It is considered yelling. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2010 Posts: 10,294 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,294 | We are glad it worked out for you. Stovebolters prefer you don't use all CAPS in your threads. It is considered yelling. WILLIAM, Not this Stovebolter. Yell away brother! Now if you were to use all lower case letters, I would wonder if you might be as meek as a mouse.  Carl
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Perhaps William is hard of hearing  (Just bugging fellas!) | | | | | Joined: Dec 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 113 | Mine has started grinding going into 4th gear. Is this the same issue or similar? should I be looking at something different all together? 1950 3100, 4 spd trans. I believe the transmission is a 1952. The other gears seem to work fine, though it seemed I almost had to be at a complete stop to shift down into 2nd but that has happened off and on in the past so I'm not sure its related. | | | | | Joined: Dec 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 113 | I should note that if I let the clutch out and push back in between 3rd and 4th gears it goes smoothly.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Mine has started grinding going into 4th gear. Is this the same issue or similar? should I be looking at something different all together? 1950 3100, 4 spd trans. This is not the same thing. You have a bad syncronisor on 4 th gear in the trans. In your next post you mentioned letting the clutch out in between the shift. This is called double clutching. It was nessesary back before they had syncros in them. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 113 | Thanks. I was afraid of that. And I always called it double clutching but someone corrected me once and said there was more to double clutching than that. Can't recall what he tried to explain to me but just in case, I avoid using that term when asking for advice from guys that know more than me. I want to be as accurate as I can. | | |
