0 members (),
125
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Would anybody be willing to PM me there phone number, so I can text them pictures of my GM tranny, and see if they can identify it? Apparently I'm not smart enough to link pictures from my phone to on here.  IT was hooked to a 1958 261 engine I acquired. TIA.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 |
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Can't sleep either huh? Numbers will tell Tim, but by looking at the shifter cover, it looks like a New Process. To bad that 5th speed wasn't an over drive, I'd think about using that in my '50. Think we're zeroing in on it Brian. I'd bet Ken has seen a bunch of these. dg
Denny G Sandwich, IL
| | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Denny and Tim thanks for the help. I'm thinking it's a new process since reverse position is up and to the right. This thing must of come from a pretty good size truck. I'll and get numbers and post them later.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Clark and New Process both have reverse toward the right and up towards the dash. New process has 1st to the left and towards the dash while Clark has first to the right and toward the seat. They both come in direct and overdrive. In the mid 50's, New Process was more popular with 5th over than Clark with 5th over. | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Found a saw tooth circle with NP close together in the circle. Also found a 6-10-58 date, and a C-911-71 number. The PTO on the side had serial#9070494 model# BAC86 2B. Arrow Gear. Broken Arrow O.K. Does this thing have any value? Or should I take it to the scrap yard to be turned into 3 Subaru's  it's HEAVY!!! again thanks for the reply's.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | People who are restoring trucks a little larger than a 2 ton could use it, But finding someone who needs it may be difficult. The ones with overdrive or the close ratio between 4th and 5th are the most desirable. If you have a shed and are not crowded for space, it is worth keeping. But if you have no space, sometimes you have to do what you gotta do. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | NP-540,,541,542 series, keep it, or advertise it, they are good trans'. I put one in an early Bronco behind a Buick V6, really liked it. Great for starting with a load, get going in first, 4 close ratios thereafter. Ones with Chevy bolt pattern and short input shafts are hard to find.
| | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Ed, mine has the Chevy bolt pattern and the 6.5" short input shaft. So again Denny, Tim, Ken, and Ed, thank you for helping figure out what I got.
