2 members (Donf, Gray_Ghost),
91
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,757 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2015 Posts: 28 | All,
We just acquired a 1950 3100 and are in the process of going through it. The engine is a 235 from 1956 according to the serial number. I have looked at the drive train and do not see any universal joints. I would like help in identifying how the drive train is put together. See pictures at https://www.dropbox.com/sh/fmbsrf6tgo5hcvt/AAAu4-oVxu_dkHsW_8CF0eCba?dl=0
Any input is appreciated.
Deron
Deron
God made man to go by motives, and he will not go without them, any more than a boat without steam or a balloon without gas.
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Deron
Welcome to Stovebolt! The photos you have are of a typical CLOSED driveline with a 3-speed transmission. If you open the ball assemply (the greasy end) you will find the u-joint inside. The did it like this since most roads were not paved then to keep dirt and dust out of the driveline.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jul 2015 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2015 Posts: 28 | Sweet,
Thanks for the input. Did they not put a U-joint on the rear?
Also, where do you find the serial numbers on the rear end and transmission?
This truck was requested by my 16 year old son for his first vehicle. It is refreshingly simple to work on. I have not been around these old trucks for a long time.
Deron
Deron
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | No U joint in the rear. The whole axle is on a pair of pivots used provide movement.
As for casting numbers. On the rear axle they are on the passenger side. I'm not sure which side the transmissions are located. But keep in mind they may be buried under grease. Take a wire brush to both sides and I'm sure you will find it.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jul 2015 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2015 Posts: 28 | Thanks for the information.
Here is the engine's serial number.https://www.dropbox.com/s/l79xk3mjg1ecjy3/20150627_142209.jpg?dl=0. Can you help me decipher it?
I know it is not original to the truck.
Deron
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The number looks more like a poorly stamped "55" instead of "56". Might need the casting date from the block, which can be found near the starter, to confirm. However, in either case, the same application code was used for both years, in this case, a Passenger car 235 originally with a Powerglide transmission.
Bill Burmeister | | | | | Joined: Jul 2015 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2015 Posts: 28 | You guys are awesome with your knowledge and helping me out with this subject. I will have to get all the component numbers together and post here for you input.
Thank you very much for helping a novice figuring it all out.
Deron
Deron
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | HO prefix on transmission code indicates 1950 truck 3-speed masde in Muncie (standard transmission): http://chevy.oldcarmanualproject.com/chevyresto/5052.htmIf the rear end is from a 1950 3100 truck, the code should start with HE or HF. | | | | | Joined: Jul 2015 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2015 Posts: 28 | Ok finally got to clean tbe pumpkin and found HE 316. https://www.dropbox.com/s/cnqy7dlc9fd9f1y/20150912_132246.jpg?dl=0Does this number make sense? Thanks,
Deron
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | HE316 HE = 1950 3100 (enclosed drive shaft - torque tube) H = 1950 E = 3100 316 = date code 3 = month = March 16 = day = 16th Look at this page: http://chevy.oldcarmanualproject.com/chevyresto/5052.htm | | |
