2 members (carbking, 2-Ton),
128
Mod | | | Forums66 Topics128,105 Posts1,056,539 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 76 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 76 | Is there supposed to be a gasket on the water pump of a 1950 216 / 235 engine? Either between block and pump or rear pump cover and pump..... Mine is leaking from behind the pump but dont see a gasket listed in the catalogs. Thanks | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | The shop manual does mention a plate gasket there; it also says "Replace Water Pump" as the remedy for all problems. Photo credit to Chevrolet Motor Co. with this picture of the engine diagram that shows the gasket in between the plate & pump AND between pump & block.. $1.95 Brad
Last edited by Uncle Brad; 08/13/2015 4:30 PM. Reason: good gosh I am having keyboard issues
Wrench Fetcher, PhD | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | plate-to-pump gasket - in Step 8 directly under Figure 114pump to block gasket - in Step 17 directly under Figure 59Both those gaskets should come in an engine gasket set. Maybe someone knows the part numbers for the gaskets when bought separately? You will need a gasket set to match the year of your water pump (if the year/style of water pump does not match the one used on that engine/block - for, example: a newer style block with an older style water pump, using an adapter plate). | | | | | Joined: Mar 2010 Posts: 10,293 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,293 | Make sure that the water isn't coming from the weep hole at the bottom of the pump toward the rear. You might need a mirror to see it. This would indicate a bad internal water pump seal. Carl
