1 members (Thomaslb),
138
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Used some corn head grease in my steering box. Bottom bearing race disintegrated. Cleaning out the grease has turned into a nightmare. Gummed up my parts cleaner, Purple power is just not cutting it. Any ideas or suggestions?
Thanks Andy
Sometimes you're the window Sometimes you're the bug
| | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | Corn head grease is supposed to be oil like when working and thick grease at rest. SO heat should be the help in making it flow out better. Boil it out, or heat gun
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Denny, with out you what would we do. | | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | That was far to simple. Thanks Denny. Any alternatives to corn head for the steering box?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Corn head grease is the cheapest and easiest to find grease that comes close to the original specifications.
Penrite Steering Gear lube is more expensive and harder to find, but it matches original specifications. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | While JD Corn Head grease is used by many of the guys, I've found Penrite to be a lighter lubricant which actually will flow in a slump test without heat. Since the steering box does not see very much heat I believe the bearings are better supplied with the Penrite lubricant. The down side to it is two fold. One it's four or five times as much as Corn Head grease. Two it was only imported to the States by one vendor the last time I bought some, so it's pretty hard to get. To spread the shipping cost from California I ordered several bottles, which I keep on hand for the next one. http://www.pbase.com/dennygraham/image/115320099Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Everytime this issue comes up, I am reminded of the local farmer who uses STP for that. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That local farmer (and most other people who use STP) most likely have a drip, drip, drip . . | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Okay, I'll ask the dumb question.......... Anything wrong with using multipurpose red grease in the steering box? It looks like that's what was in mine when I bought it. I'm assuming corn head grease is much more dense & stiffer?
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | No Cornhead or the 00 grade grease is less dense more fluid. Multi purpose or axle grease will not flow back upon itself. Imagine taking a handful of multi grease out of the container it comes in... does it find a new uniform level or does it leave a void? That's what happens it the steering gear box as well. You want that grease on the gears not the walls of the steering box.
| | | | | Joined: Feb 2000 Posts: 5,208 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,208 | | | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | Well thanks CASO for setting me straight. Never thought of it that way. So now, I think it will be appropriate to take out all the red multipurpose grease in my steering box, then go down to the John Deere store and get some corn head grease and then repack my steering box with it. That multipurpose grease has been in my steering box a long time, so I hope there hasn't been too much damage done.
And thanks Joe H for the link to the page describing all the types of grease. Never knew there were so many!
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Well I guess you could dump some 90wt in there and then sit in the driveway and drive like a madman for an hour to mix it into the red devil blood already there... or not
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Old, heavy grease can cake up the ballnut enough that the self levelling stuff can't get in there. IMO disassembling the ballnut and cleaning it and the balls/guides completely are vital to ensure smooth operation. If there's wear present it's most likely gonna be the balls/guides/nut as the gears themselves are pretty durable and have lash adjustment available. I used a cake decorating bag and a spatula to fill mine.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Oct 2012 Posts: 130 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 130 | So is there way to get the old grease out without disassembling the steering box so I can add JD Corn Head grease? | | | | | Joined: Oct 2012 Posts: 130 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 130 | | | | | | Joined: Dec 2011 Posts: 241 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 241 | Old, heavy grease can cake up the ballnut enough that the self levelling stuff can't get in there. IMO disassembling the ballnut and cleaning it and the balls/guides completely are vital to ensure smooth operation. If there's wear present it's most likely gonna be the balls/guides/nut as the gears themselves are pretty durable and have lash adjustment available. I used a cake decorating bag and a spatula to fill mine. X-2 on disassemble and clean up. This way you can inspect it properly. If your pour something in to clean it theres nothing to say you got all the old crud out. Mark
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | You can dig out what you can reach with a flat screwdriver, then top it off with 90 wt gear oil and drive it a while until it works its way in and mixes in with the old crud, then either siphon it out, or leave it in if it doesn't leak. Carl
| | | | | Joined: Dec 2014 Posts: 66 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 66 | This weekend I nearly emptied a 500 ml bottle of the Penrite Steering Box Lube into my '59. Thirsty bugger, but I must say the improvement on today's drive was noticeable. I used the Ziploc baggie method to fill the box, after squeezing in as much as would flow, and having the front wheels jacked up, I'd turn the steering wheel full lock 2-3 times. This would draw the Penrite down into everything. Repeat this a dozen or so times and it filled up nicely. I left a 1/4" or so air space. The big thing I noticed being improved upon was how the steering felt when going over sharp bumps, like an expansion ripple. Before I'd often get a metallic clank sound thru the steering wheel. Tonight hitting that sort of pavement, things were just a nice thud/thump. Impressive, I should have done it long ago. Best $28.50 spent so far.
'59 Apache ‘21 Beta 390RS ‘18 BMW R1200RT '12 Ford Flex '13 Aprilia Tuono ‘11 Ducati Hypermotard Salisbury, MD
| | | | | Joined: Feb 2013 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 56 | If it any help I once overfilled the gearbox on my JD corn head with grease and removed the excess with a simple suction pump, it was viscous enough to be pulled out easily. Pat
1966 Chevy C 30 1 ton truck
