0 members (), 102 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#1117823 08/07/2015 1:10 PM
Hi, I bought new rubber boot and pedals and starter boot from:
http://www.americanclassic.com/
But the e-brake rubber boot I got was for 1/2 ton.
Not for a 2 ton big floor handle.
I have searched all over and can't find a suitable one.
Anyone who has a partnumber I can search for ?
/Ulf
My Chevy Viking 1959
Ulf Hedlund. Eskilstuna. Sweden
[email protected]
Also:
Ford Galaxie 4 dr 1959
Ford Custom 4 dr 1964
Ford Mustang GT 2005
I looked, and could not find one for my 47 1.5 ton. I made a flat aluminium plate that fits as tight as possible around the lever and release rod, and placed it under the carpet so it slides back and forth with the lever. It works well as a seal and doesnt interfere. I cut a slit in the carpet just big enough for the lever and its movement.
'47 Canadian RHD 1.5 ton truck
That part is not being reproduced...I've talked to vendors about having it made, but there isn't enough demand to justify the cost.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks Mike, saves me a lot of time surfing smile
Okay then... will just have to use a piece of leather and squeeze it under the metal frame on the floor, and then use a shoestring around the lever. That will do the trick.
[email protected]
Also:
You might try a leather (hot rod) gear shift boot and invert it on the brake lever so it hangs below the floor. That way you won't see it and it will have enough travel/flexibility and not tear. Just a thought...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
YES !!! Of course, why didn't I think of that ????
Thanks Mike smile smile
[email protected]
Also:
