8 members (Mike B, WICruiser, Youngin' Tut 59, Pete1946, Bizaircon, klhansen, LuckyLee, 1 invisible), 72 guests, and 1 robot.
Topics128,140
Posts1,056,770
Members48,454
I have a 51 3100 that I am trying to decide on an engine. I have an early 60's 283 that is rebuildable. Is this engine capable of anything besides a trip to the post office? I have heard that with a little love- it can come close to the mid 60's 327. I am looking for near, if not 300hp- but a daily driver also. Should I scrap the engine and get a crate- or give it a go with someones good advice and direction?????
My experience with 283s is limited, however, my uncle used to have a '57 Bel Air with a 283 and 2-speed powerglide, every time I drove it I was impressed by the power available, even in that heavy car. The PG was a bit strange though - you would rev way up, then drop way down when it shifted.
1954 GMC De Luxe COE
283 is a good engine but is not an inexpensive rebuild--cost can be similar to inlines. Probably why folks go to 350/350 swaps.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
A 292 produces as much power, and more low end torque as the 283. But the 283 probably has more "naturally aspirated" potential.
-ftyler
For a street V8, the most you can hope for is 1.2 HP per cubic inch. That means that a 283 could make a maximum of 339 HP if you got the combination perfect.
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
Chiphead,
So that's it. No wonder 300 HP 350s are so easy to build! And they're CHEAP too! eek
The 1.2 HP per CID assumes a V8 with greater than 9:1 compression and proper selection of fuel, carburation, valvetrain, heads, ign, and exhaust systems. I've got a Pontiac 400 squirreled away for a 1.2 HP per CID project. Bored .030" will give 406 CID. You do the math.
*evil laughter*
chip
Check out this '67
http://www.stovebolt.com/gallery/cooley_craig_1967_01.htm
A built 283 and the owner says it runs 13.80 in the quarter. Sounds impressive to me.
Blaine Dumkee
59 GMC 9314
Fort Smith NT
www.flickr.com/photos/northerngmc/
No wonder I find it fun to drive my wife's 1.8L New Beetle Turbo with 150hp (the new model has 180 hp) with far better than 1.2hp per cubic inch displacement (I think). I got no problem with speed and power; in fact, I loves it.
However, I like driving a stovebolt because it is a stovebolt. Yes, I do like driving my '54 with a modestly enhanced 261 (but it still has ancestral resemblance - it's ontogeny recapitulates its phylogeny).
Nonetheless, I like reading these discussions about Frankenstein monsters.
(What do you think, will this inappropriate statement get a rise out of a few people?)
Tim
I'll find out in a few weeks how close to the 300 hp rating I came to with the 283 I warmed over a tad in this 50 Willys Jeepster I'm building for my Dad to putt around in. The 283 is bored .030 over, has a 10/10 crankshaft, true double roller timing chain, high volume oil pump, Comp Cam with 480 lift,194 Fulie heads, Polished Aluminum dual plane intake, 650 double pumper and a Recurved HEI Distributor. It sounds Sweet!!!
Joe
Joe
13.8s with a 283 pushing heavy c20 longbed 4x4..??? Very hard for me to believe, but impressive if true.
-ftyler
Well he did say it took a lot of tuning and it was on slicks to run 13.80.
He also said it wasn;t a highly streetable engine.
Blaine Dumkee
59 GMC 9314
Fort Smith NT
eb1 Offline
HOTROD Magazine had a "modern 283" recipe in the august '02 issue. They suggested vortec heads and super victor intake and also said it would be a high rpm motor(475hp @ 8000). Magazine also listed part numbers. My guess is this would cost pretty close the same as rebuild of any inline motor but would be different.
'64 C10-292 with TBI, 4speed, 3.42 rear
Sweet!!! I'll try to get me a copy of that issue. I'm glad to hear its not crazy.
They made those spring cars run like scalded dogs well into the 70s!
It takes a big dog to weigh a ton
