4 members (gswbbc, Lugnutz, Dennys28, jmoore), 75 guests, and 3 robots.
Topics128,031
Posts1,055,434
Members48,422
#1117322 08/04/2015 6:31 AM
I seem to have a little bit of up and down play in my steering wheel, or column. Anyone know if that is typical or, if not, where do I start to tighten things to alleviate the play? It's not the main nut that holds the steering wheel on, more like in the shaft itself somewhere along the column. Thanks.
63 Chevy Fleetside Rat Rod
67 Pontiac GTO
Riding in the Passing Lane
The lower brg. is stuck to the shaft. It is supposed to float on the shaft so the spring under it pulls the strg. wheel down against the upper brg.
1972 Chevy c10 Cheyenne Super
The lower steering column bearing is well known for failing and eating into the steering shaft. For more on that check out post #25 here
Hope this helps thumbs_up
_____
Thank you. Could have something to do with my horn problem. Can that be just be tightened? And if so, where would I start, somewhere in the column or at the steering gearbox? Or does that require a re-build? Haven't worked on steering before so I'm not that familiar with it.
67 Pontiac GTO
I'd pull the entire column out of the truck and rebuild it. Sounds like a lot of work but it really isn't that hard to do.
The lower bearing slides onto the steering shaft from the steering wheel... so the column has to come out to replace that lower bearing.
My link above has instructions thumbs_up
_____
Thank you. I think I'll do that. What parts would I be looking to replace, if any, when I do the rebuild?
67 Pontiac GTO
You will need a lower brg. & possibly the upper brg. If it has a shifter in it you might need a shift tube.
