8 members (Gdads51, Otto Skorzeny, warlock, RoadsScholar, Ponchogl, 55shaker, k2handyman, 5 Window 9434),
104
Mod | | | Forums66 Topics128,048 Posts1,055,626 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2015 Posts: 37 | I seem to have a little bit of up and down play in my steering wheel, or column. Anyone know if that is typical or, if not, where do I start to tighten things to alleviate the play? It's not the main nut that holds the steering wheel on, more like in the shaft itself somewhere along the column. Thanks.
63 Chevy Fleetside Rat Rod 67 Pontiac GTO
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The lower brg. is stuck to the shaft. It is supposed to float on the shaft so the spring under it pulls the strg. wheel down against the upper brg. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | The lower steering column bearing is well known for failing and eating into the steering shaft. For more on that check out post #25 hereHope this helps _____ John | | | | | Joined: Jul 2015 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2015 Posts: 37 | Thank you. Could have something to do with my horn problem. Can that be just be tightened? And if so, where would I start, somewhere in the column or at the steering gearbox? Or does that require a re-build? Haven't worked on steering before so I'm not that familiar with it.
| | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I'd pull the entire column out of the truck and rebuild it. Sounds like a lot of work but it really isn't that hard to do. The lower bearing slides onto the steering shaft from the steering wheel... so the column has to come out to replace that lower bearing. My link above has instructions _____ John | | | | | Joined: Jul 2015 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2015 Posts: 37 | Thank you. I think I'll do that. What parts would I be looking to replace, if any, when I do the rebuild?
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You will need a lower brg. & possibly the upper brg. If it has a shifter in it you might need a shift tube. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
