| | | Forums66 Topics128,042 Posts1,055,516 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Hi, I bought new rubber boot and pedals and starter boot from: http://www.americanclassic.com/But the e-brake rubber boot I got was for 1/2 ton. Not for a 2 ton big floor handle. I have searched all over and can't find a suitable one. Anyone who has a partnumber I can search for ? /Ulf My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Jan 2010 Posts: 120 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 120 | I looked, and could not find one for my 47 1.5 ton. I made a flat aluminium plate that fits as tight as possible around the lever and release rod, and placed it under the carpet so it slides back and forth with the lever. It works well as a seal and doesnt interfere. I cut a slit in the carpet just big enough for the lever and its movement.
'47 Canadian RHD 1.5 ton truck
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | That part is not being reproduced...I've talked to vendors about having it made, but there isn't enough demand to justify the cost. Mike B  | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Thanks Mike, saves me a lot of time surfing Okay then... will just have to use a piece of leather and squeeze it under the metal frame on the floor, and then use a shoestring around the lever. That will do the trick. My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | You might try a leather (hot rod) gear shift boot and invert it on the brake lever so it hangs below the floor. That way you won't see it and it will have enough travel/flexibility and not tear. Just a thought... Mike B  | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | YES !!! Of course, why didn't I think of that ???? Thanks Mike  My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
