2 members (3B, Cosmo), 149 guests, and 3 robots.
Topics128,080
Posts1,055,951
Members48,430
#1117644 08/06/2015 2:47 AM
Hello All,
I seem to have an atypical rear rear leaf spring to axle mount. Has anyone seen the rear axle bolt to a mount that is U-bolted to the leaf spring like in the photo? Rear End
Not sure what truck or rearend you have but it looks like a typical set up like on the AD's style trucks 47-54.
Hang tight, someone will be along shortly with the absolute answer.
U
U Offline
Welcome to Stovebolt; what truck year & model are we looking at?
It looks clean, for sure.
Brad
edit-I'm not the absolute answer
Wrench Fetcher, PhD
What make, year, and size truck?
The photo is not very clear.
Does your rear spring seat look like this? (Figure 86)
Looks like a typical torque tube arrangement to me.
Carl
Yep sir,
Axle housing ears and spring seat with rubber bushing 1929 - 1957 Chevrolet Master Parts & Accessories Catalog
Prevents binding when leaf springs compress and telegraphing of road vibrations into truck/car body.
Only on torque tube/Closed Drive Shaft equipped trucks and cars.
Different angle pic
Benefits of Torque tube/Closed Drive Shafts
Jim Carter Viewer Tip
Absolutely impervious to rear spring wind up, when used on soft ground
Wow,
You all are awesome! That is it, spring seat with rubber bushings. Anyone know where I can get the rubber bushing or other accessories for the spring seat? All the aftermarket vendors I have checked don't show it (LMC, Brothers, Jim Carter, Classic Parts)
The truck is a 54 chevy 1/2 ton
Originally Posted by blumarln
Wow,
Are the original ones bad?
Wow,
You can Revulcanize them (You send in your spring seats and they put in new rubber) at Steele Rubber Pricey.
Or press THESE into the Spring Seat cast metal housing. Affordable
While you have it all apart you should replace the Rubber Washer Spring Seat Seals. 2 per spring seat.
Once you replace the springs seats you have to seat them.
Spring Seat seating instructions on page 2, Read "Adjust this type of Seat as follows":
Page 1
Page 2
First you have to find out if they are bad.
Is there any noise or sloppiness in the axle to spring seat connection?
