1 members (51sub), 128 guests, and 2 robots.
Topics128,125
Posts1,056,338
Members48,440
#111754 07/27/2003 5:37 AM
HELP!!!!! I now have two 1940 1/2 tons ( I'm so proud) takin up space in my shop and I'm trying to sort out the various box panel and tailgates and front panels and don't seem to be coming up with anything consitant. I had some info form a fella on the forums with some pics and measurments but lost it and him in the big crash of '03. I have a pair of 3/4 ton box sides but am building a 1/2 ton truck. Lots of running boards but they seem to be all a different length. Can any one share pics and specific measurements with me? I would like to just get my box sides bend for these two trucks with out having to mail order in a box or parts. Get i touch with me directly if you want and share what you can........I think the last fella who got some info to me was Brian ???? Sorry, now I realize what that computer guy meant when he said "only God Saves". I'll be a lil more diligent now....
#111755 07/28/2003 4:32 AM
What'cha need to know? I'm too dumb to post pictures, but let me know specifically what measurements you need.
Dennis
40 Chevy 1/2 ton
#111756 07/30/2003 12:55 AM
also a 40 1/2 ton here ans digi-cam what u need
#111757 07/30/2003 3:13 PM
Hi Axle- On a '40 1/2-ton, the boxsides should be 79-3/4" long. They are the same from '40-'46. The front panel should be 48-1/2" wide and the tailgate a hair narrower at 48-1/4". Anything wider is later than '46, anything narrower is '39 or older. The '40 tailgate should have the embossed "Chevrolet" script stamped into it.
To be long remembered as he's cruising in
The Passing Lane
#111758 08/01/2003 5:17 AM
Hi Fella's and Thanks for the timely reply. I have collection of parts that I am trying to sort out and come up with a proper set of measurements to build a set of box sides and front panel. I understand that the front panel should be 48.5" wide ( the "new" one I have is only 47") so that shouldn't be a problem to have bent up. I have two sets of box sides ( one set is 88" long with three stake pockets per side, the other is the right length , but looks like a set of 47-55 fender bolt holes ) The fender holes line up on the 88" ones( two sets about 3" apart as apparently the Sask. farmers used to raise thier fenders for???)so it will be a good match for height but I am wondering about the axle notch and its height up from the bottom of the panel and where it begins front and rear? I also have a tailgate in great shape except it is 49.75" long so I figure it for a 47-55 truck. So Thanks again, and if any one knows the axle notch measurements at the side panel bottom, send em on up ( pics are good too!)
#111759 08/12/2003 3:42 PM
Thanks to all those who sent me measurements and pics. If I can't build one now, I'll be in big trouble. I'll post some shots when its done. Thanks again
