2 members (LAROKE, 78buckshot),
113
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | It hasnt been driven in 15 years, and im currently doing the restoration on it. I have no idea if it still has the 4.88 gears or not it came with. the motor is a 1958 235ci tied to a 4speed. Any idea how fast I will be able to go?
1950 Chevy 3600
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | If it is the original gears 50 to 60 range is to be expected. That is keeping the engine in a comfortable rev range.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | An original 1950 3600 supposedly came with a 4.57 rear-end. Is yours original. As Martin posted, for either 4.57 or 4.88, 50-60 MPH (60 would be noisy, probably). http://chevy.oldcarmanualproject.com/chevyresto/5073a.htm | | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | i honestly dont know if its original or not. I would guess it is, but i do not know. I kinda hope ist the 4.57. For some reason i thought it originally came with a 4.88
1950 Chevy 3600
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I have read that center sections on 3/4 ton would interchange up through 1972. If this is so then a pumpkin from a later model with big block and automatic should be in the 3's. 60mph should be real comfortable with these. If heavy hauling or trailer pulling is on the menu then the stock gears are better.
Evan
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yo won't find anything in the 3s. 4.10 is about as good as it gets, with 4.57 and 5.13 being the only other options.
Bill Burmeister | | | | | Joined: Feb 2011 Posts: 12 New Guy | | New Guy Joined: Feb 2011 Posts: 12 | Remember that these 3600's were available with everything from 15 inch rims to 17.5 rims. the tire diameter will make a big difference in your top speed. My truck came with 15 inch split rims. | | |
