1 members (Hotrod Lincoln), 41 guests, and 0 robots.
Topics128,035
Posts1,055,560
#111742 11/24/2003 10:59 PM
Fox
Offline
Got the steel for my floors, and i'm asking for tips before i start. Any you can think of are welcome. Thanks.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
#111743 11/24/2003 11:56 PM
Is the cab on the frame? If it is make sure the mounts are bolted down so the cab wont flex. Depending on how much you are doing you may want to weld in some added support. Mine is off the cab so I built a wood dolly and rails to bolt it to to simulate the frame. Seemed to work well.
#111744 11/25/2003 12:24 AM
Leave the doors on it while you are welding so that you know if the cab gets warped. If you experience changes in how the doors close go back and fix it before you get too far. The cab depends a lot on the floor for its rigidity.
Paint & Body Shop moderator
#111745 11/25/2003 2:32 AM
I
I Offline
Makes me wonder if the doors did not close properly on my truck was because of the holes in the floor. even though they were fairly small
Don't you know who I think I am?
I've been thinkin' about freaking out. If I could just find the time.
http://community.webshots.com/user/ifrizlfri
#111746 11/25/2003 8:31 AM
Fox
Offline
the cab is off the frame, the mount braces under the floor also need to be replaced. how exactly do you brace the cab. Tack weld some angle iron across the doors. I will be doing the entire floorpans, and the kick panels just under the dash. any other info? thanks again
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
#111747 11/25/2003 6:22 PM
I would probably weld supports from side to side and front to back down low to stabilize the floor area since u are doing the whole floor.
#111748 11/25/2003 9:16 PM
I braced my cab with old discarded bed rails (found 'em). I cut to fit inside the hinge pocket and tack welded them in place. They worked well, but I wish I had instead bolted plates to the hinge locations using the old hinge bolts and then welded the braces inplace onto those plates.
(Maybe Next time)
I was able to (and did quite often) roll the cab over on it's firewall to gain access to the underside whilst I replaced the forward cab supports. The roll-a-round device I used was (2) cheap 700# capacity dollies from Harbor Freight ($14ea) bolted together with some 2x4s that fit under the support areas of the cab (where it sit at this moment durnit).
The floors went in nice (thank god for floor mats).
Terry
1953 1/2 ton
#111749 11/27/2003 12:42 AM
if they are separate panesl,do one panel at a time
lay a panel down and tace around it if possible
then cut it out smaller than needed then trim making sure its not to big.
#111750 11/27/2003 8:55 AM
Fox
Offline
Anybody have some pics of the operation?
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
#111751 11/28/2003 4:59 AM
In the Links section, you will find one to "Chuck the Truck". That site has a great supply of photos and information. Also, if you go to "Old Iron Chief", they have some project pictures and one is a red truck with a lot being replaced.
1951 1 Ton Completed
