1 members (Rusty Rod),
80
Mod | | | Forums66 Topics128,127 Posts1,056,680 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 79 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 79 | OK.. I know it is a truck forum and have used the site for not only my truck, but also my 235 powered 57 chevy 210.. I acquired a 49 Pontiac some time ago and just now started work on it. I bought a 6 volt battery and installed it. Everything is original, but I noticed that the generator is 12 volt. At least that is what the metal tag states. I got the car running, but was leery about the generator, so I unhooked it. It appears that the generator was hooked up a long time ago, but I didn't think that it was a good idea. Any thoughts on this? Can you run a 12 volt generator on an otherwise 6 volt car? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not if the generator is actually putting out 12V, it'd fry the battery if the regulator didn't start smoking first, but you might check what the regulator is [and light bulbs], someone may have converted it to 12V previously - the starter will work fine on 12V
Bill | | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | The regulator will have 12V or 6V stamped on it somewhere if its aftermarket, or at least most of them did. If its still a Delco reg. it will have the last few numbers stamped in the mounting base. If you have that give me the numbers and I can tell you if its 6 or 12 volt Ken | | | | | Joined: Aug 2001 Posts: 79 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 79 | The regulator has a paper tag on it that is illegible. All the lights are 6 volt and the coil is 6 volt. I guess I'm glad I unhooked it before I started it. Its just weird that it was on there and wired up. Now I guess I need to hunt down a 6 volt generator.. | | | | | Joined: Feb 2004 Posts: 29,837 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,837 | According to my 1940-53 Motor Magazine repair manual, the 49-50 Pontiac ran a 30 amp 6 volt generator, Delco part #1102711. The corresponding regulator is a Delco #1118301. A 49-50 Chevrolet generator, same amp capacity, is an 1102710, and the manual lists the same regulator as the Pontiac.
Olds and Cadillac run a 40 amp generator, with a different regulator part number. Jerry
| | | | | Joined: Aug 2001 Posts: 79 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 79 | Thanks Jerry! I saw that Wilson Auto Electric has a cross to the delco 1102711. Their part number is 92-01-3008 and can be purchased through NAPA. It is listed as 6 volt, 30 amp, CW rotation, negative polarity. Their part also crosses to numerous generators. Can I assume that this will work? Or will I need to find the Delco? | | | | | Joined: Feb 2004 Posts: 29,837 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,837 | The generator doesn't know what name it has- - - - -as long as the specifications are right, it should work. It's not uncommon for a generic rebuilt unit to cross over several OEM applications. No problem with a generator, and usually generic regulators are OK, but beware of "one size fits most" carburetors! It seems that Delco changed numbers for the same basic unit from year to year, possibly as a method of monitoring warranty coverage, slight production run differences, etc. Jerry
| | | | | Joined: Aug 2001 Posts: 79 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 79 | Thanks for the advice! I may end up converting to a 6 volt alternator. Right now I'm troubleshooting the starter. This car has sat for 50 years, so I'm sure a lot of things need attention.
And I know what you mean about carbs. I've fought that battle before! | | | | | Joined: Feb 2004 Posts: 29,837 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,837 | I believe I could outrun anyone who wanted to GIVE me a 6 volt alternator, and I certainly wouldn't buy one. They're almost all made with proprietary components, they're horrendously expensive, and if one breaks down, you'll have a horrible time getting it fixed. Did I mention they're expensive? Jerry
| | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | Jerry, I have a 6 volt alternator on my 53 and it is a great improvement over the generator. And yes it cost a few bucks and yes it will be fixed, if any any malfunctions by the manufacture. I would highly recommend the alternator over the generator if built correctly!! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | If I were you Joe, I'd simply use the one marked 12v as a core and trade it in for a rebuilt 6v generator since everything else in the system appears to still be 6v. And.......what's wrong with a Delco 6v generator??? Been running the totaly stock 6v electrical system on my 1950, 3604 for 10 years now and have never had a problem with it. Drive it day and night, hot summers and cold winters. The battery is from Farm & Fleet installed Oct, 2008, http://www.pbase.com/dennygraham/image/160427599 the generator and starter rebuilt at the same time, http://www.pbase.com/dennygraham/image/149240750 http://www.pbase.com/dennygraham/image/121070577 a new Regulator was installed, lighting and wire connections were all cleaned. The battery is re-charged after start up http://www.pbase.com/dennygraham/image/160427600 within a few miles and the lights http://www.pbase.com/dennygraham/image/138714066are as bright as they would be with a 12v system. For my 12v needs I use a 6v to 12v voltage booster cube to power my tachometer and Sony AM/Fm/CD. http://www.pbase.com/dennygraham/image/139692811 So....what's wrong with a Delco 6v generator??? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Dec 2008 Posts: 901 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 901 | I'm a witness, Denny's 6 volt starts up just as quick as my 12 volt in my truck.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | My experiences are the same as Denny's regarding 6v: good battery good heavy cables good starter good generator good voltage regulator good grounds (my weak point for many of my lights/lamps)
Nonetheless, no problems | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Denny, What is the purpose for the two digital volt meters? Two different readings on same source? Is that the discrepancy between the two meters? Although not much of a difference. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Denny, was doing a comparison of measurements: shade-tree vs full-sun? | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | New electrical diagnostic terminology. shade-tree vs full-sun  | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | One meter is HF the other is a Fluke, $19.95 vs $199.95. I just know there would be someone that would question the accuracy of the Harbor Freight meter so I used the two for comparison.
30 millivolts is nothing and could be the difference in leads, contact area or how good the contact is being made. So don't loose the point, that the 6v generator will pump up the battery just hunky dory even if it's a seven year old cheapo from Farm & Fleet.
Bill....glad to see you back with the pack. It's been so long that I've had someone to argue with that I thought you might have fallen off the edge. Hope your crop is as good this year as ours is in Illinois. Only problem is, everyone's crop is good.
dg
