1 members (UtahYork), 80 guests, and 2 robots.
Topics128,049
Posts1,055,637
#1117132 08/03/2015 9:53 AM
I'm having issues with the engine of my '41 1/2 ton shutting down for no apparent reason.
I currently have the metal sheathed ignition cable that goes to the coil.
Is there any reason that I can't, or shouldn't, replace this arrangement with automotive primary wire and an on/off toggle switch. I want to retain the stomper starter.
I am not concerned about security.
Thank you,
Ed
There is no reason you can,t do what you described. I just took my ignition switch apart and ran a new thermoplastic insulated wire inside the armorrd sheath.
