1 members (Russ_B_10),
91
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2015 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2015 Posts: 34 | I'm having issues with the engine of my '41 1/2 ton shutting down for no apparent reason.
I currently have the metal sheathed ignition cable that goes to the coil.
Is there any reason that I can't, or shouldn't, replace this arrangement with automotive primary wire and an on/off toggle switch. I want to retain the stomper starter.
I am not concerned about security.
Thank you, Ed | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | There is no reason you can,t do what you described. I just took my ignition switch apart and ran a new thermoplastic insulated wire inside the armorrd sheath. | | |
