Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (farmallb, baldeagle, TGP, 1955 1 Series, Dennys28), 71 guests, and 3 robots.
Topics128,005
Posts1,055,266
Members48,418
#1116850 08/01/2015 9:27 PM
Yesterday after a car show, setting in the hot sun all day, was headed home, drove about 3 miles and the truck quit. Would no start, everything looked OK, had fuel and spark, but would not start. Let sit for about 20 min. then tried to start still no go, when remove the gas cap and the tank was under pressure, so I left the cap loose and let sit about 10 more min. put cap back on the it started right up drove it the rest of the way home with no more stalling. I thought the gas cap was a venting cap, new cap the box it came in said it was a vented cap. What is it suppose to be? 53 3100 235 root
root #1116946 08/02/2015 10:32 AM
Hi Root, "had fuel and spark" has to be a wrong statement. I think you were not getting fuel, possibly vapor locked. A vented cap only means air can get into the tank however pressure can build up in tank under the cap. It should have a vented cap. mtneermike
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
root #1116963 08/02/2015 2:06 PM
Did you mean that the tank was under vacuum??? Certainly sounds
like a classic un-vented tank problem.
dg
Denny G
Sandwich, IL
root #1117039 08/02/2015 10:54 PM
Denny and Mike, no it was like the tank was pressurized. If I suck on the hole on the inside of the cap, I get air, if I blow it seals off. The tank is behind the seat. I am thinking that the tank was pressurized and causing the carb to flood. root
